Photonics
Photonics
Lumapi – Insufficient Memory even though I have memory
    • dobiej
      Hi All
      I've run into a problem where when I create an FDTD instance in Lumerical I get an error mid-way through build saying
      "The program must be terminated due to insufficient memory."
      I have 128GB RAM and 4TB storage so this isn't an issue. I've tried increasing the mesh size but to no avail.
      What's strange is if I build it manually I can run it fine. Would anyone know what the issue could be? I've tracked it on Task Manager and there doesn't seem to be a spike in specs or anything.
      Any help would be appreciated.
    • dobiej
      For reference here is the first first part of the code. Specifically I get the error on line 59. Above there are just variables that define things.
      The x span is set to be 1 micron with conformal variable 0 mesh and the background index is set to 1.333.
      When I set the x span to be 10nm the program is not shut down due to insufficient memory but the elements are added to the build extremely slowly (140 seconds to add 5 elements). Before it used to start running the simulation in under 10 seconds. Nothing has changed but this has happened all of a sudden.
      When I construct this in GUI it works fine and I can use python to load files and save them just not create new ones.
    • Guilin Sun
      Did you find the solution as this post was closed?
      Usually I suggest to test the Lumerical script first to make sure everything works fine when Python script causes some issues.
      Currently creating geometris with Python is a little slow which is under improvement. Please use struct for parameter assignments to improve the efficiency.
  • The topic ‘Lumapi – Insufficient Memory even though I have memory’ is closed to new replies.
