Ansys Products
Ansys Products
LSTC License Server Error
    • rsaunders1
      When attempting to start the LSTC license server, we encounter the following error message:
      Both hosts mentioned in the error are correctly listed in the server_data file.
      Could you please advise on how to resolve this issue?
      Thank You,
      Ron
    • Alex Rycman
      Hello Ron,
      The whole server ID key must match between server_data and LSTC_LICENSE_INFO file. Did anything change in the machine that runs the license server? Is the LSTC License Manager running on a VM?
      The LSTC License Manager can operate on a Virtual Machine (VM). However, if the virtual machine experiences downtime (due to maintenance, power outage, etc.) or is rebooted, the LSTC License Manager will not start again because it detects a hardware change (HOST ID change). This issue arises because the vmxnet3 interface functions as a Virtual Machine Ethernet adapter, rather than physical hardware. To restart the LSTC License Manager, a new license key is required. We advise configuring the LSTC License Manager to run on a dedicated hardware to avoid such disruptions.
      Please reach out to the account manager to re-issue a new license file.
      Thank you,
      Alex
