March 7, 2024 at 5:40 am
Fady Elshazly
SubscriberHello,
In my Lsdyna model I have two warning messages:
1- Shell thickness is less than 0.5Â
2- For element beam, beam distance is too small.Â
Would these warnings cause any numerical problems?
Also, I want to add contact for (beam to beam) and (beam to shell), what would be the best choice. I have tried several contacts but none produced the desired interaction.
ThanksÂ
March 7, 2024 at 8:51 pm
Jim Day
Ansys EmployeePlease provide the full text of the Warning messages, including the Warning number.
For beam-to-beam, try *CONTACT_AUTOMATIC_GENERAL with SOFT=1 and the beam parts all on SURFA.  Leave the SURFB side blank.
For beam-to-shell, try *CONTACT_BEAM_TO_SURFACE with SOFT=1.
March 7, 2024 at 9:03 pm
Fady Elshazly
SubscriberThanks for your reply.Â
The warnings are:
1: SECTION_SHELL(ID: 1): thickness is less than 0.5. Refby 2 parts: 1 2..... warning(2)1: ELEMENT_BEAM(ID: 2449): Beam distance is too small..... warning(47177)ÂFor beam-to-beam contact, the contact should be created for each beam part. Say if I have three different beams interact with each other, I will create three contacts, right?ÂÂAnother question: for discrete beams(form 6), what is the best material to be assigned to act as a nonlinear spring with one axial DOF?ÂThanksÂ
March 7, 2024 at 9:14 pm
Jim Day
Ansys EmployeeI'm not familiar with those warnings.  Include images that show the warnings exactly as they appear in the LS-DYNA output (d3hsp or mes*).
You can create a part set with all three beam parts and put that part set as SURFA of one *CONTACT_AUTOMATIC_GENERAL.
If are just concerned only about 1 dof, I'd probably use a spring element defined with *ELEMENT_DISCRETE and *SECTION_DISCRETE. For the material, use *MAT_SPRING_ELASTOPLASTIC or *MAT_SPRING_NONLINEAR_ELASTIC, depending on what sort of nonlinear behavior you want.
March 7, 2024 at 9:43 pm
March 12, 2024 at 4:18 pm
Jim Day
Ansys EmployeeThose screenshots are from what software?
If LS-DYNA doesn't complain, I wouldn't worry too much about it.
- The topic ‘lS-DYNA Warning messages-Contact’ is closed to new replies.
5664
1890
1419
1304
