October 27, 2023 at 1:23 am
October 27, 2023 at 6:44 pm
igandiko
Ansys EmployeePlease check if the computed and test histories for the first couple of iterations make sense by plotting them together. If the optimization ran only 1 design at iteration 3, it means it either convereged in two itearitons or there is an inherent issue in the setup. Maybe the computed and test histories are in different units?
October 27, 2023 at 8:14 pm
November 1, 2023 at 5:26 am
igandiko
Ansys EmployeeHow is the error being calculated? Are you using MSE response as the objective? How does the optimization history plot look for the objective and design variables? Perhaps optimum value hit the variable bounds?
- The topic ‘LS OPT’ is closed to new replies.
1311
