LS Dyna
LS Dyna
LS-DYNA submodeling: Why can’t local model simulation read the cut boundary file from global model?
    • pengchengyin
      Dear all:
      Currently, I am learning how to perform submodeling simulation in ANSYS/LS-DYNA. I am very confusing what I meet. The following figures shows the global and local model, the code for cut boundary file and result. The Von-Mises contour of local model shows that there is no stress in the model which is wrong..it looks like the simulation of local model does not read the cut boundary file from the global model. Does anyone know how to solve this problem? it is because the code of cut boundary or something else?
      Thank you!
      Global Model
    • Ashish Khemka
      nnPlease see if the following link helps:nnnRegards,nAshish Khemkan
  • The topic ‘LS-DYNA submodeling: Why can’t local model simulation read the cut boundary file from global model?’ is closed to new replies.
