LS Dyna
LS Dyna
LS-Dyna orthotropic material model with viscoelasticity in different direction
    • Dennis Chen
      Hello, does LS-Dyna have a material model that can handle orthotropic material that's also viscoelastic in each of the 3 ortrhogonal directions.
      basically, is it possible to define prony series terms for each of the 3 axis of an orthotropic material model?  If this isn't possible, is there a material model that can do this?
      this is not a duplicate from the one in Ansys Mechanical section, I am looking at both solvers.
    • Ram Gopisetti
      Hi Dennis Chen,
      There is a MAT_213 COMPOSITE_TABULATED_PLASTICITY_DAMAGE material model that supports viscoelastic behavior in all three axes. Please refer to Card 9 of this material model for details regarding the viscoelastic formulation. For a deeper theoretical understanding, you may also consult the following resource: https://lsdyna.ansys.com/wp-content/uploads/attachments/t5-2-c-composites-131.pdf. Additionally, it would be helpful if you could provide the commercial or trade name of the material in question to offer more precise recommendations.
      Best regards,
      Ram
    • Dennis Chen
      Ram, thank you.    do you know if Ansys Mechanical/APDL have something similar to Mat_213?  I will make sure to look into this.   Thank you.
      I won't risk mentioning work related stuff on these forum posts but I really appreciate your info
      Best
