August 19, 2024 at 9:39 am
August 20, 2024 at 4:21 pm
igandiko
Ansys EmployeeNCPU is used for SMP and Hybrid solvers. The correct command to run MPP LS-DYNA is,
/path/mpirun -np 128 /path/ls-dyna.exe i= input.k
If 128 MPI ranks are on different hosts, you may need a file with a list of hosts. Please see here for more information (https://ftp.lstc.com/anonymous/outgoing/support/FAQ/mpp.getting_started).Â
August 21, 2024 at 1:19 pm
Atish Gawale
SubscriberHi,
I am running fluid analysis using CESE solver.
I am able to use higher processor now. I ran with 16 processors and I get following error.
With MPP_D and 1 processor there is no error. with higher processors I get following error.
mes0000
No elements with calculated timesteps    1 t 0.0000E+00 dt 2.22E-09 flush i/o buffers      08/21/24 13:46:17    1 t 0.0000E+00 dt 2.22E-09 write d3plot file      08/21/24 13:46:17 *** Error 100116 (CESE+116) (processor # 0)    20959704 errors detected in CESE solver during step = 1 *** Error 100117 (CESE+117) (processor # 0)       1 of these CESE solver errors detected on processor # 0 *** Error 100118 (CESE+118) (processor # 0)   Errors detected in CESE solver integration step.   Please check each processor's message file for details. When error termination was triggered, this processor was past the output routinesÂmes0001 - to mes 0015 i got following error.ÂNo elements with calculated timesteps
 *** Error 150209 (CHEM+209)
   Chemistry EOS nonlinear temperature solver failed to converge.
   Error code = 50 Last iterate temperature = NaNÂDo I need to include any control cards for MPP (*CONTROL_MPP_XXXXX)?ÂÂRegards,
Atish-
July 10, 2025 at 9:44 am
Jacques
SubscriberHi Atish Gawale,
Have you found the reason for that, I get the same problem with you.Â
*** Error 100116 (CESE+116) (processor # 0)Â Â Â Â Â Â Â 29 errors detected in CESE solver during step = 36ÂÂ *** Error 100118 (CESE+118) (processor # 0)Â Â Â Errors detected in CESE solver integration step.Regards,
Jacques
July 16, 2025 at 2:36 pm
Atish Gawale
SubscriberThis error is very common in *CESE fluid solver with *CHEMISTRY and related to non-physical model setup or non-convergence as well.Â
Please check if you have included all necessary keywords in your model.
Atish
3492
1057
1051
965
942
