March 23, 2024 at 7:34 am
Fady Elshazly
SubscriberHello,Â
Is there a way to check the system total stiffness from the lsprepost or the ouput files?Â
thanksÂ
March 26, 2024 at 11:21 pm
Reno Genest
Ansys EmployeeHello Fady,
How would you get the total stiffness of the system experimentally? You could put the system in a press and get the stiffness in compression. Or you could put the system in a a tension test machine and get the total stiffness in tension. You can model this test with LS-DYNA and extract the force required to compress or extend the system along with the displacement. You can get the force from the *BOUNDARY_PRESCRIBED_MOTION (bndout) or the contact (rcforc) and the displacement at a node on the press (or extension machine). Then, you can plot the Force vs displacement curve and calculate the stiffness.
Let me know how it goes.
Reno.Â
March 26, 2024 at 11:24 pm
Fady Elshazly
SubscriberThank you so much for your reply. I mean when doing the eigen analysis, is there any way to report the system stiffness used for calculating the modes frequencies.Â
thanks
March 27, 2024 at 12:24 am
Reno Genest
You should be able to output the stiffness matrix as follows:
you can get the stiffness matrix, the mass matrix, the nodal information to map the rows of the independent system to the nodes and rigid body center-of-masses, and the unscaled eigenvectors. See MTXDUMP (2nd field, 2nd line of *CONTROL_IMPLICIT_SOLVER) and EVDUMP (6th field, 2nd line of *CONTROL_IMPLICIT_EIGENVALUE)."
Reno.
- The topic ‘Ls-Dyna model total stiffness’ is closed to new replies.
5039
1749
1387
1248
