July 7, 2023 at 5:08 am
Fady Elshazly
SubscriberHello,
Is there any way to control the stiffness matrix formulation in LS-DYNA implicit. I mean to form it at the beginning of the solution and not to change it.
Is there any way to save only the results (displacement, velocity and acceleration) of specific nodes in an ASCII/text file directly without the need to open lsprepost again?
Thanks -
July 7, 2023 at 12:13 pm
Ram Gopisetti
Ansys EmployeehiÂ
elobrate your first point ( what method you are look for, etc)Â
try using the database_history_node (id, set)
in smp run it outputs nodeout which has following header with time stampÂ
 nodal point  x-disp   y-disp    z-disp    x-vel    y-vel    z-vel    x-accl    y-accl    z-accl    x-coor    y-coor    z-coor
in mpp run it will be output in binout you can also check the elout databaseÂ
cheers, ramÂ
July 7, 2023 at 7:36 pm
Fady Elshazly
SubscriberI am using mpp and history node id. I need to save the recorded nodes in history node id in a file that can be red directly without the need to open lsprepost again. I mean to import it in matlab or something and read it as a txt or other readable extensions.
July 7, 2023 at 3:50 pm
Jim Day
Ansys EmployeeTo retain the same stiffness matrix for each step in a LINEAR implicit analysis, set NSOLVR= -1 (negative one) in *CONTROL_IMPLICIT_SOLUTION.
- The topic ‘LS-DYNA implicit stiffness matrix and output’ is closed to new replies.
4492
1494
1376
1209
