March 5, 2023 at 8:28 am
kwak dongkyu
Subscriberhi i download above image ansys workbench. and i wanted to use ls-dyna that is in workbench
but when i tried to run the ls dyna the error message comes out like
'the demanded solver was not found in the specified path' what can i deal with it
do i also need to download the ls-dyna student version like below. thank you
March 5, 2023 at 12:25 pm
peteroznewman
SubscriberYes, download LS-DYNA also.
March 6, 2023 at 12:46 am
kwak dongkyu
Subscriberbut it still didn't work..
March 6, 2023 at 3:07 am
peteroznewman
SubscriberYes, but now you have the LS-DYNA solver installed. Go to the Start Menu and under ANSYS 2022R2 LS-DYNA Student select LS-Run. Use that to submit a .k file to the solver. Under that same folder is LS-PrePost that you can use to build a .k file of your model and look at the results.
Good luck!
March 6, 2023 at 10:45 am
kwak dongkyu
Subscriberthanks for your reply
but i want to ask you one more question.
can i export .k file in ansys? if i save the ansys file its file type is wbpj.
March 6, 2023 at 11:45 am
peteroznewman
SubscriberI'm not an expert at LS-DYNA, I'm an expert at Workbench. I had a quick look in the free Ansys (Student) Workbench and in LS-PrePost and noticed that in Workbench, I can export a Nastran file and in LS-PrePost I can import a Nastran file. I often do meshing in a Modal analysis block and Export Nastran file then open that in Femap where I finish preparing the file to submit to the Nastran solver.
On a paid Ansys Workbench license, LS-DYNA is an analysis system that you can drag into the Project Schematic, just like you can with Explicit Dynamics. This feature is not included in the Student license.
July 5, 2023 at 5:00 pm
煜杰 葉
SubscriberHello, I am facing the same issue. Is there any solution available now? Thank you
July 12, 2023 at 4:15 am
Tonmoy
SubscriberI think the best step-by-step solution for this problem is already available in the following forum post: /forum/forums/topic/error-inside-ansys-ls-dyna-an-error-occurred-inside-the-solver-module-general-error/
I'd the same problem with our license and solved it following that process. Also, after installing, double check if your license server is properly defined.
I hope it helps
- The topic ‘ls dyna has no solver’ is closed to new replies.
6144
