LS Dyna
LS Dyna
LS Dyna FSI ICFD pressure oscillation
    • Webster
      Hi community!
      I am using LS Dyna for a FSI simulation. My simulation terminated as the result of an ICFD mesh error. The result comfirmed the large deflection in geometry was attributed to a sudden yet unreasonable oscillation in my fluid pressure (a sudden overshoot).
      The problem is not associated with the time step. The time increment is ~ 5E-5, so I am not worrying about this. The velocity inlet - pressure outlet boundary conditions might be the culprit, but I am not sure.
      Are there any techniques (or, tricks) I can deploy to stablise the pressure in simulation?  Or, alternatively, do you have any other suspects that I should be careful about?
      Thank you.
    • Reno Genest
      Hello Binghuan,
      Could you share a screenshot of your pressure vs time graph to show to overshoot?
      What velocity inlet and pressure outlet boundary conditions are you using?
      Are you using a consistent unit system? This is very important. You will find more information here:
      https://lsdyna.ansys.com/consistent-units/
      Which version of LS-DYNA are you using? Have you tried with the latest R14.1 solver? Make sure to use the double precision MPP solver:
      https://user:computer@ftp.lstc.com/user/mpp-dyna/R14.1.0/windows/
      Are you using a loose or strong coupling FSI? From our ICFD training course: "Problem: It has been observed that loose coupling between an incompressible fluid
      and a solid frequently yields unstable computations. The mass ratio between fluid and structure has a significant influence on the stability
      of the system. The bigger the ratio , the more unstable the system. A smaller timestep will cause the instabilities to appear earlier. In order to overcome those effects, it is mandatory to use an iterative procedure also
      called strong FSI coupling."
      So, if you are using a loose FSI coupling, I would suggest you try the strong FSI coupling.
      ": In order to trigger automatic strong coupling, the LS DYNA implicit solver
      must be used for solid mechanics (No further modifications of the CFD input deck is needed). First tip: In case of stability issues, it may be useful to change the Newmark integration
      parameters (see *CONTROL_IMPLICIT_DYNAMICS). γ = 0.6 and β = 0.4 for instance
      yield a more diffusive but more stable solution. Second tip: Lower the tolerances of the implicit solve (see
      *CONTROL_IMPLICIT_SOLUTION. Third tip: Increase the timestep. In some cases, this may help with stability to the
      expense of accuracy.".
      You will find FSI with ICFD examples here:
      https://www.dynaexamples.com/icfd/basics-examples/strong_fsi
      https://www.dynaexamples.com/icfd/intermediate-examples/Intermediate_fsi_flap
      The last example above has a full tutorial on Youtube:
      https://www.youtube.com/watch?v=eLI4p5Ifcds
      Let me know how it goes.
      Reno.
  • The topic ‘LS Dyna FSI ICFD pressure oscillation’ is closed to new replies.
