June 6, 2023 at 8:02 am
o.duncan
SubscriberSimilar to the post linked below - I am recieving this error when running LSDyna via workbench (but with LSDyna version 13.1.0 for windows, not 13.0 for Linux - so slightly different to the linked post). I have checked various simulation types, and file directories, and it seems nothing will run. Does 13.1.0 also contain a known bug, and if so, which update should I install to repair it?
Error “*** Error 70022 (OTH+22)” Ls-Dyna on Linux (ansys.com)
June 7, 2023 at 3:43 pm
igandiko
Ansys EmployeeI think similar to the solution in the link, you would need R13.1.1. Did you try installing the service pack for 2022R2?
This is a known bug in version 13.1 (in 2022 R2 installation). LS-DYNA checking out permanent ANSYS LS-DYNA license. Version 13.1.1 fixes this issue.
August 16, 2023 at 5:34 pm
- The topic ‘LS Dyna – Error 70022 (OTH+22)’ is closed to new replies.
5824
