September 10, 2024 at 2:19 amDENGSubscriber
The input parameters defined by keywords CESE_MAT_GAS and CESE_EOS_IDEAL_GAS specify which regions exactly, and aren’t the initial conditions for the entire fluid defined by CESE_INITIAL_CHEMISTRY?
If there are mixed gases with different temperatures, pressures, or compositions within the same fluid domain, should different SET_SOLID definitions be used, represented by different CESE_INITIAL_CHEMISTRY_SETS, and will multiple defined SETs overlap?
What is the maximum number of grids that the CESE solver can compute, and can the number or size of grids lead to result errors?
I encountered a detonation using the same CESE parameters with fewer grids and only CESE grids, but when I increased the grids and added aluminum alloy, I got the following errors: Error 150209 (CHEl+209) Chemistry EOS nonlinear temperature solver failed to converge. Error code=50 Last iterate temperature = -0.10209E+04 Error 150210 (CHEI+210) Nonlinear chemistry EOS temperature solver returned a negative value. CHEM_COMBUST_I: Failed to converge What could be causing this error?
September 13, 2024 at 7:57 amAshish KhemkaForum Moderator
Ansys employees cannot comment on this query. Please wait for other members to chime in.
Ashish Khemka
September 18, 2024 at 4:22 pmAtish GawaleSubscriber
1) If you have defined composition of fluid using *CHEMISTRY keywords, then you need to use CESE_INITIAL_CHEMISTRY otherwise use CESE_INITIAL. Then you must also specify the CESE_MAT_GAS and CESE_EOS.Â
2) Yes, you need to create the SET_SOLID for each composition and they should not overlap.
3) Grid size should be very small. Min size can be less than 1cm in the combustion domain. I will recommend structured hex mesh.Â
4) Error is typical with CESE solver. If solver finds anything non-physical then it gives only one typical error for any problem. Be is related to mesh size, time step size, non-physical pressure, temperatures, boundary conditions or any other problems.Â
Atish
- LS-DYNA Installation Issues with Student Workbench 2024 R2
- Cross-coupled stiffness elements in LS-DYNA
- Initial Velocity Generation
- MAT072R3- concrete damage rel3 validation
- Initial Stress Shell Application and HistVarCosine in LS-DYNA
- shape memory alloy material in LS-DYNA
- *** Error 40058 (SOL+58) retractor 1000002:convergence failure at time1.01E+02
- LS-Dyna, Negative volume problem.
- Mohr_Coulomb material model (MAT_173)
- Fluid-structure interaction coupling
1932
823
599
591
366
