November 22, 2023 at 4:21 pm
Atish Gawale
SubscriberHello,
I have two solid PARTs, I defined both of them in CESE_PART. Hence Section ID and Material ID need not be defined.Â
But still I am getting following error.
Error 10125 (KEY+125)
   Checking PART and SECTION definition input.
   PART ID 1 with
   SECTION ID 0 does not exist.
   This is PART 1 in the order of input.Can you please help on this?
Atish -
November 27, 2023 at 7:11 am
Ushnish Basu
Ansys EmployeePlease take a look at the examples here for guidance if you haven't already:
https://www.dynaexamples.com/cese
The Dual-CESE method is recommended over the legacy CESE method
November 27, 2023 at 11:37 am
Atish Gawale
SubscriberHello,
Thanks for the information.
Can we use *CHEMISTRY card with Dual-CESE method?
My problem requires use of CHEMKIN files by using *CHEMISTRY_MODEL keyword.
December 1, 2023 at 4:46 pm
Atish Gawale
SubscriberI have high pressure gas at the centre of cube surrounded by air domain. I am trying to solve sudden expansion of gas in air domain. I am able to achieve mechanical equilibrium (pressure and velocities of the fluid are equal) but not the thermal equilibrium (temp are not exchanged). There is patch of temperature which is constant.Â
- The topic ‘LS DYNA CESE solver’ is closed to new replies.
3407
1057
1051
896
887
