January 30, 2024 at 5:36 pm
gomez
SubscriberA researcher at Robert Morris University is trying to runÂLS-DYNA (ls-dyna_mpp_d_R12_1_0_x64_centos78_ifort160_avx2_intelmpi-2018) on our RHEL 8.8 cluster (bridges2.psc.edu) at the Pittsburgh Supercomputing Center (PSC) while checking a license off their Robert Morris University (RMU) license server - the server is here: 27014@acadlms03.ad.rmu.edu. ÂÂWe verified we can contact the license server from the Bridges2.psc.edu cluster at PSC and can query it, e.g.:Â$ /opt/packages/ansys/shared_files/licensing/linx64/lmutil lmstat -c 27014@acadlms03.ad.rmu.edu -aand it reports 0 licenses in use for many features including dyna. We can access the license server from the compute nodes in the cluster.ÂBut, we are not getting LS-DYNA to talk to the license server. We tried setting (bash shell): Â  export LSTC_LICENSE=network
  export LSTC_LICENSE_SERVER=27014@acadlms03.ad.rmu.eduÂand running LS-DYna with:Â
$  mpirun -np 1 ./ls-dyna_mpp_d_R10_2_0_x64_centos65_ifort160_avx2_intelmpi-2018 i=Main_ALE_Boundary_Controls.k memory=500mÂbut we get the error message: License option : check network license only   Date: 01/29/2024    Time: 12:16:58 Â
 *** License problem ***
 Network license: *** Error License client cannot find any servers to talk to.        Servers may be down, not ready, or the wrong version.ÂIs there a set of ports beyond obvious one (27014) that must be opened in the RMU firewall that would no be obviously open as per the "lmutil lmstat -c ... -a" test above?ÂThanks, -Roberto Gomez, gomez@psc.edu. (412) 855-0020 -
January 31, 2024 at 5:28 pm
Reno Genest
Ansys EmployeeHello Roberto,
Are you using the Ansys license and the Ansys license manager to run LS-DYNA? If so, you need to set the following environment variables on the client machine (cluster):
export LSTC_LICENSE=ansys
export ANSYSLMD_LICENSE_FILE=1055@acadlms03.ad.rmu.eduThe default port for the Ansys license is 1055.
Let me know if this helps or not.
Reno.
January 31, 2024 at 6:38 pm
gomez
SubscriberHi Reno,
I think the answer is yes, they are using the Ansys license manager, they provided me with their Entitlement ID if you need it to verify.
This is what I get (first few lines) when querying their server:
[gomez@r002 temp]$Â /opt/packages/ansys/shared_files/licensing/linx64/lmutil lmstat -c 27014@acadlms03.ad.rmu.edu -a | more
lmutil - Copyright (c) 1989-2015 Flexera Software LLC. All Rights Reserved.
Flexible License Manager status on Wed 1/31/2024 13:29License server status: 27014@ACADLMS03.ad.rmu.edu
  License file(s) on ACADLMS03.ad.rmu.edu: C:\Program Files\ANSYS Inc\Shared Files\Licensing\license_files\ansyslmd.lic:ACADLMS03.ad.rmu.edu: license server UP (MASTER) v11.19.0
Vendor daemon status (on ACADLMS03.ad.rmu.edu):
 ansyslmd: UP v11.19.0
Setting just those two environment variables and retrying, I end up with:
[gomez@r002 temp]$ mpirun -np 1 ./ls-dyna_mpp_d_R10_2_0_x64_centos65_ifort160_avx2_intelmpi-2018 i=Main_ALE_Boundary_Controls.k memory=500m
 License option : check ansys licenses only
   Date: 01/31/2024    Time: 13:14:50    ___________________________________________________
   |  Livermore  Software  Technology  Corporation  |
   |  7374 Las Positas Road              |
   |  Livermore, CA 94551               |
   |  Tel: (925) 449-2500  Fax: (925) 449-2507    |
   |  www.lstc.com                  |
   |_________________________________________________|
   |  LS-DYNA, A Program for Nonlinear Dynamic    |
   |  Analysis of Structures in Three Dimensions   |
   |  Version : mpp d R10.2.0  Date: 03/05/2019   |
   |  Revision: 135267      Time: 15:49:10    |
   |  Features enabled in this version:        |
   |   Distributed Memory Parallel          |
   |   CESE CHEMISTRY EM ICFD STOCHASTIC_PARTICLES  |
   |   FFTW (multi-dimensional FFTW Library)     |
   |   ANSYS License (ans160)            |
   |  Licensed to:                  |
   |  Platform  : Intel-MPI 2018 Xeon64       |
   |  OS Level  : Linux CentOS 6.5 uum        |
   |  Compiler  : Intel Fortran Compiler 16.0 AVX-2 |
   |  Hostname  : r002.ib.bridges2.psc.edu      |
   |  Precision  : Double precision (I8R8)      |
   |  SVN Version: 135714               |
   |  Unauthorized use infringes LSTC copyrights   |
ANSYS LICENSE MANAGER ERROR:
Could not connect to any license server.Â
The server is down or is not responsive.Â
  ANSYSLI_SERVERS: 2325@acadlms03.ad.rmu.eduÂ
  FLEXlm Servers: 1055@acadlms03.ad.rmu.edu ******** UNEXPECTED ERROR - NETWORK TASK CONTROL INCONSISTENCY *******    Â
 Please contact your ANSYS Sales Representative or ANSYS, Inc.
I don't know if this helps, but I thought of checking if those ports are open on their firewall:
[gomez@r002 temp]$ telnet acadlms03.ad.rmu.edu 2325
Trying 192.203.233.236...
^C
[gomez@r002 temp]$ telnet acadlms03.ad.rmu.edu 1055
^CI think they are not open, while the port that I was told the license server is setup on (27014) is open:
[gomez@r002 temp]$ telnet acadlms03.ad.rmu.edu 27014
Connected to acadlms03.ad.rmu.edu.
Escape character is '^]'.
^CConnection closed by foreign host.Your help is much appreciated.
Best, -Roberto
January 31, 2024 at 6:51 pm
Reno Genest
Please make sure port 1055 and 2325 are open. I don't know what port 27014 is.
Let me know how it goes.
Reno.
April 3, 2024 at 10:59 am
1617836513
Subscriber  ___________________________________________________
   | www.lstc.com |
   | Version : smp s R8.1.0 Date: 02/24/2016 |
   | Revision: 105896 Time: 14:28:04 |
   | Shared Memory Parallel |
   | Interactive Graphics |
   | ANSYS Database format |
   | ANSYS License (ANSYS145) |
   | Licensed to: |
   | Platform : WINDOWS X64 |
   | OS Level : Windows 7/8/10 & Server 2008/2010 |
   | Compiler : Intel Fortran XE 2013 MSVC++ 2010 |
   | Hostname : xianxianxian |
   | Precision : Single precision (I4R4) |
   | SVN Version: 105897 |
 Executing with ANSYS license
 Input file: d:\penetr~1\budong.k
 The native file format : 32-bit small endian
 Memory size from default : 20000000
As a new user of ansys, I may have encountered an "Unauthorized use infringes LSTC copyrights" issue. When I modified an environment variable, the issue was not resolved. I don't know what other problem is causing me to not be able to do the calculations properly. Thank you for your help.
April 4, 2024 at 5:14 am
1617836513
   |  www.lstc.com                  |
   |  Licensed to:                  |
 Executing with ANSYS license Input file: d:\penetr~1\budong.k
 Memory size from default   :   20000000 on UNIX computers note the following change:
 ctrl-c interrupts ls-dyna and prompts for a sense  switch.
 type the desired sense switch: sw1., sw2., etc. to continue
 the execution.  ls-dyna will respond as explained in the users manual  type            response
  quit   ls-dyna terminates.
  stop   ls-dyna terminates.
  sw1.   a restart file is written and ls-dyna terminates.
  sw2.   ls-dyna responds with time and cycle numbers.
  sw3.   a restart file is written and ls-dyna continues calculations.
  sw4.   a plot state is written and ls-dyna continues calculations.
  lpri   toggle implicit lin. alg. solver output on/off
  nlpr   toggle implicit nonlinear solver output on/off
  iter   toggle implicit output to d3iter database on/off
  prof   output timing data to messag and continue
  conv   force implicit nonlinear convergence for current time step
 ********  notice  ********  notice  ********  notice  ********
 * This is the LS-DYNA Finite Element code.          *
 * Neither LSTC nor the authors assume any responsibility for *
 * the validity, accuracy, or applicability of any results   *
 * obtained from this system. The user must verify his own   *
 * results.                          *
 * LSTC endeavors to make the LS-DYNA code as complete,    *
 * accurate and easy to use as possible.            *
 * Suggestions and comments are welcomed.  Please report any  *
 * errors encountered in either the documentation or results  *
 * immediately to LSTC through your site focus.        *
 * Copyright (C) 1990-2016                   *
 * by Livermore Software Technology Corp. (LSTC)        *
 * All rights reserved                     *
 ********  notice  ********  notice  ********  notice  ******** Beginning of keyword reader                  04/04/24 12:32:40
 Memory required to process keyword   :    350314
I don't know what problems my file is having with the calculations.
April 4, 2024 at 4:53 pm
Reno Genest
Ansys EmployeeHello Ji,
Please create a new forum post and clearly state the problem and the error message.
Thank you.
Reno.
- The topic ‘LS Dyna – can’t reach license server’ is closed to new replies.
5649
1885
1404
1303
