LS Dyna
LS Dyna
    • amir.mb1377
      Hello
      I imported a meshed model from another software into LS Dyna software. Can I change the mesh in LS Dyna?
    • Reno Genest
      Hello Amir,
      You imported a mesh in LS-PrePost correct? Was it successful? Can you inspect the mesh? You should be able to save the keyword file (.k) which is the LS-DYNA input file format:
      Reno.
    • amir.mb1377
      Hello Reno,
      I imported from Abaqus software to LSDyna software. It has been successful. But I want to change the mesh. which command can I change it?
    • Reno Genest
      Hello Amir,
      I don't have experience with meshing in LSPP; I usually use Ansys WB to mesh CAD geometries for LS-DYNA.
      You can try the following training for LSPP:
      https://ftp.lstc.com/anonymous/outgoing/lsprepost/Training/Intro/
      Also, you will find LSPP training on the Ansys learning hub (if you have access):
      https://jam8.sapjam.com/home/bRkQVuQCyaRN2s3K5mv5yM
      Search for "LS-PrePost" in the above  webpage.
      Hopefully someone with meshing experience with LSPP will be able to help you.
      Reno
    • amir.mb1377
      Hello Reno
      Ok
      Thank you a lot
Viewing 4 reply threads
  • The topic ‘Ls dyna’ is closed to new replies.
