July 25, 2023 at 10:01 pm
Alek Nino
SubscriberI am currently running a simulation of a human airway and using the LRN SST to model turbulence and I would like to know if the LRN option accounts for turbulence or if I also need to enable the gamma-transport-eqn? In STAR CCM, transition options are disabled automatically and their help states that LRN accounts for transistion. I just wanted to confirm if this was the same with ANSYS or not.
July 28, 2023 at 3:55 pm
Kalyan Goparaju
Ansys EmployeeHello,Â
If using the K-Omega Viscous Model with Low-Re Corrections turned on, that does not automatically turn on transition modeling. You need to manually select either one of the transition models from the Transition options.
Thanks,
Kalyan
- The topic ‘LRN SST K-omega and Transition’ is closed to new replies.
- Two-way FSI simulation
- RIBBON WINDOW DISAPPEARED
- Battery Pack cooling
- ISAT ABORT error
1494
1386
1209
