Lox Properties
    • Zwernjayden
      I'm using dpm, and the properties of Lox default to vaporization temp: 55k, boiling point: 90.2k, and I need to enter the vapor pressure manually. Do I need to adjust these based on the domain pressure its being injected into? And is the vapor pressure of Lox just 1atm because its naturally a vapor?
    • Prashanth
      Hi, you can use DEFINE_DPM_PROPERTY for setting vapor pressure as you like, and make vaporization as a function of pressure
  • The topic ‘Lox Properties’ is closed to new replies.
