May 29, 2023 at 5:42 pm
fares abbara
SubscriberSo i have been working for a while on an FSI model for a bifurcating tube with cyclic loading on the outer surface. I have recently managed to get my system going successfully. However, due to high computational time i had to run my model on an HPC service provided by my university. when my model ran i was working on ansys 2023, however the HPC has the 2021 version. To work my way around the issue i redid my model on ansys 19.2 on the university on computers and tried running it on 2021 version on the HPC. Unfortunately the model did not run and i recieved the error message specified in the title of this post. what could the issue possibly be?
Moreover, i tried running the model again on the 2023 version and i recieved that error as well.
May 30, 2023 at 1:16 pm
Federico
Ansys EmployeeHello Fares,
Are you running intrinsic FSI from Fluent or via Systems Coupling? why is your model not running anymore on 23R1? Can you share more text from the transcript/console to provide more context as to where your simulation fails?
May 30, 2023 at 4:19 pm
fares abbara
SubscriberHello Federico,
Thank you for your reply.
I am running my FSI using system coupling. When i reran my model on 23R it was the same error message as 19.2. Here is the text i got after analysis initialization.
+=============================================================================+| || Analysis Initialization || |+=============================================================================+===============================================================================Traceback (most recent call last):File "PyLib/kernel/remote/RemoteObjects.py", line 28, in _nodeCallerFile "PyLib/physicscoupling/importer/Importer.py", line 36, in setExistingConnectionRuntimeError: Low-level communication error -15: Connection was closed+-----------------------------------------------------------------------------+| Low-level communication error -15: Connection was closed |+-----------------------------------------------------------------------------+Traceback (most recent call last):File "PyLib/main/Controller.py", line 147, inFile "PyLib/main/Controller.py", line 143, in _runFile "PyLib/main/Controller.py", line 92, in _executeScriptFile "PyLib/kernel/commands/__init__.py", line 31, in readScriptFileFile "PyLib/kernel/commands/CommandManager.py", line 169, in readScriptFileFile "wb2cosim.py", line 4, inSolve()File "PyLib/kernel/commands/CommandDefinition.py", line 74, in funcFile "PyLib/kernel/commands/__init__.py", line 28, in executeCommandFile "PyLib/kernel/commands/CommandManager.py", line 122, in executeCommandFile "PyLib/cosimulation/externalinterface/core/solver.py", line 125, in executeFile "PyLib/cosimulation/solver/__init__.py", line 123, in solveFile "PyLib/kernel/util/Memory.py", line 177, in wrapperFile "PyLib/cosimulation/solver/__init__.py", line 519, in __initializeControlledFile "PyLib/cosimulation/participantmanager/AnsRpcParticipant.py", line 151, in initializeOutputsFile "PyLib/physicscoupling/importer/__init__.py", line 93, in setExistingConnectionFile "PyLib/kernel/remote/RemoteObjects.py", line 45, in funcFile "PyLib/ComputeNodeCommand.py", line 94, in newfuncFile "PyLib/ComputeNodeCommand.py", line 70, in raiseExceptionRuntimeError: Low-level communication error -15: Connection was closedShutting down System Coupling compute node processes.
- The topic ‘“Low-level communication error -15: Connection was closed” when i run my FSI.’ is closed to new replies.
5674
1890
1419
1304
