March 4, 2024 at 1:10 pm
Jeonee
SubscriberHi,
I have done high cycle fatigue analysis (S-N Time Series) and obtained 4392 cycles. Should I do low cycle fatigue analysis (E-N Time Series) again?
March 6, 2024 at 2:44 pm
danielshaw
Ansys EmployeeProbably. SN is only valid for high-cycle fatigue (HF) using elastic stresses.  A predicted fatigue life for a ductile metal of only 4392 cycles is probably indicating low-cycle fatigue (LCF) produced by plastic strains. The predicted life of 4392 cycles is probably conservative, but if you want a more accurate life prediction, you should use EN.
March 6, 2024 at 7:24 pm
Jeonee
SubscriberYes, this analysis for Al7075-T6 and conservative. Certainty of survival is 95%Â
Thank you so much for answer
- The topic ‘Low Cycle Fatigue’ is closed to new replies.
Ansys Innovation Space
1388
1188
1095
1015
