January 6, 2021 at 3:30 pm
Narongkorn
SubscriberHi all,
I am modelling a 3D printing action from a printing nozzle to a moving bed. I import a CAD model from Inventor. After I simulated the model and display the contour of the fluid flow I cannot see the fluid inside the model (it shows only surface as the attach picture).
January 6, 2021 at 5:05 pmRob
Forum ModeratorThe isosurface of the free surface looks OK, and it is a surface you're displaying and not a filled volume. The only odd part is why there is no liquid in the inlet duct, but as the volume fraction of liquid there is 1 it won't show up in the 0.3 isosurface. What are you expecting to see? nJanuary 7, 2021 at 7:20 amKeyur Kanade
Ansys EmployeeCan you please explain more on  I cannot see the fluid inside the model. nThere are cells inside. You can create different isosurfaces. e.g. please create isosurface with X coodinate and you can see section of cells. Here you can plot contours as well. nArraynRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student CommunitynJanuary 7, 2021 at 7:21 amKeyur Kanade
Ansys EmployeeIf you want to see mesh then use Display n
Viewing 3 reply threads- The topic ‘Loss mesh in the post processing’ is closed to new replies.
5014
1682
1387
1248
