March 27, 2024 at 6:58 am
April 5, 2024 at 5:22 pm
GLUO
Ansys EmployeeHi,
Is this for 2D or 3D? In 3D you can assign lorentz force as parameter directly.
GL
April 9, 2024 at 6:40 am
vignesh.j
SubscriberHi,
Yes, i know that we can assign parameters for lorentz force & lorentz torque to different parts before starting the solver (pre-processing stage) and see their results in solution data.
I am exploring the capabilities of field calculator. For that I am trying to write an expression for lorentz force & lorentz torque in field calculator and evaluating them and compare with solution data results.
I am able to write an expression for lorentz force. But i having difficulty in writing lorentz torque expression in field calculator.
Is it possible to write an expression for lorentz torque in field calculator ?
April 10, 2024 at 11:13 pm
GLUO
Ansys EmployeeYes, I think you can use Input>>Function>>Scalar>>R to get the displacement vector.
GL
- The topic ‘Lorentz Torque calculation in field calculator (Magnetostatic)’ is closed to new replies.
5744
