Materials
Materials
Topics related to Granta Design and more.
Looking for Neoprene Rubber source
    • StevenChoong
      Anyone knows where the Neoprene Rubber material data in ANSYS is from? I would like to know its test standard.n
    • Gary_S
      The material data in the Ansys samples are generally from engineering textbooks.nUsers are strongly encouraged to obtain and validate their own material properties from their material supplier.nA recommended reference site for material data is matweb.comn
    • David Mercier
      Hi, if you use the Neoprene Rubber material data from Ansys Granta EduPack or Ansys Granta Selector, data are well referenced. As Gary said it is mainly textbooks, but data come also sometimes from suppliers or from websites.nn
    • Joy Gupte
      hello, steven
      Neprene rubber compound/sheet or product can be preapred with vriable specifcations. Tough the raw material remain same, alterations can be made by varying amount of filler, plasticizers, carbon, vulcanizing chemicals.  You can find speficatons here- neoprene-rubber-sheet
    • Binoc ngoai
      Neoprene is a petrochemical substance, which means that it is made from petroleum in a factory. Polychloroprene is made with a process called free radical emulsion polymerization, which turns natural chloroprene into synthetic polychloroprene. territorial io
Viewing 4 reply threads
  • The topic ‘Looking for Neoprene Rubber source’ is closed to new replies.
