March 9, 2018 at 2:15 pm
yusufalbadry
Subscriberi have a problem with my Ansys Fluent 17.0
i am doing a simulation over a rectangular wing ( 50cm chord , 70cm span )
the general information about the mesh isÂ
my problem is in the solution time , 50 iteration is taking about 7 hr !!!!Â
i dont know why , a friend told me that this is a problemÂ
PC specification:
8 GB ram Fury 1866 Mhz
FX 8350 8 cores ( should i overclock it ? )
1 TB Hard diskÂ
MSI 970 Gaming motherboardÂ
March 10, 2018 at 5:17 pm
raul.raghav
SubscriberYou have around 11.8M elements. You should expect the simulation to be slow but 50 iterations in 7hrs sounds wrong. Are you sure its running in parallel and not in serial?
March 10, 2018 at 10:27 pm
yusufalbadry
Subscriberyes i am running it in parallel , i am using 6 cores .
i have tried it on my laptop too , it gave me a time longer than 7 hours .
is there something wrong ?
March 11, 2018 at 10:49 pm
Raef.Kobeissi
SubscriberWhat do you mean exactly by iterations. Are you sure you don’t mean time steps? Is this a transient simulation ? When you say 6 cores do you mean 6 threads? Can you please show a picture of the residual error graph.
Regards
March 12, 2018 at 7:07 am
yusufalbadry
Subscriberthis is what i mean , i think you will understand what i mean after seeing the images , because to be honest i am not that good in english .
and to explain what i am doing .
i am doing an analysis over a 3d wing, 50 cm in chord and 70 cm span .
i really dont know where is the problem , i wish you help me .
March 12, 2018 at 7:10 am
yusufalbadry
Subscriber -
March 12, 2018 at 7:12 am
yusufalbadry
Subscriberthis is for the cores , and the question you have asked
March 12, 2018 at 9:16 am
vganore
Ansys EmployeeCan you also show how the 3D geometry was meshed? Looks like 30e5 cells were generated for simple rectangular geometry. You could reduce the cell size if possible.
March 16, 2018 at 4:35 pm
yusufalbadry
Subscriberthank you guys
it was a ram problem , i was using a double precision and coupled ( model ) .
now everything is working fineÂ
March 16, 2018 at 9:01 pm
May 3, 2020 at 8:46 am
Sherif
SubscriberI have exactly the same problem.
How did you solve it in details please.
Note that I'm using single precision
- The topic ‘Long iteration time in Fluent’ is closed to new replies.
5799
