3D Design
3D Design
Log in new Subscription license got error appear
    • kcchuah
      ? This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
    • Naresh Patre
      Hello rtssb9182 This issue has already been reported to the concerned development team and they are working to fix it. Meanwhile, please activate the subscription license through Command prompt as per steps mentioned in below article: Discovery Subscription license - Command line options - Knowledge Base - Ansys Discovery Forum
    • Naresh Patre
      Hello rtssb9182
      Were you able to activate the subscription license successfully through Command Prompt?
    • Naresh Patre
      Hello rtssb9182
      Based on the error message, it looks like it could be a firewall issue. Can you disable firewall and see if that helps? Also, were you able to activate the subscription license successfully through Command Prompt?
    • Naresh Patre
      Hello rtssb9182
      The account team noticed that the email address associated with this issue is being used by multiple users. If multiple people are sharing a single Discovery subscription, it is a violation of the legal terms and conditions of the Discovery named-user subscription license. Each user must have his or her own Discovery subscription. Ansys ID SSO detects multiple people signing in from different locations as a violation of the single-user requirement, then requires MFA or blocks the sign-in.
      The account team would still like to have some information to investigate this issue. The previous failed logins all appeared to be coming from an IP address in Taiwan, while there were passing logins from Singapore. Can you collect the timestamp of when the failure occurred that would be helpful as it looks like there are multiple users from different locations using this account.
    • kcchuah
      This company had 2 offices  Singapore and  Taiwan . the R&D team  have engineers at Taiwan and Singapore as well. So they need use same software do simulation. I don't see problem against Violation
    • Naresh Patre
      Hello rtssb9182
      The Named User (subscription) license is intended to be used by a single user. If multiple users want to use a single license, then it is recommended to switch to the floating license option. Anyways, as I mentioned in my previous post, the account team is investigating the issue and they need the timestamp of when the failure occurred. Can you please provide that information?
      Also, did the customer try activating the subscription license through command prompt that I had mentioned in one of my earlier replies? Can you also provide an update on this?
    • kcchuah
      they bought  1 seat SC and 1 seat Discovery.  they plan add 2 more seats coming. Yes they try use command prompt to activate the license. what information you want?
    • Naresh Patre
      Hello rtssb9182
      Thanks for your reply. Was the command prompt activation successful or not? If it failed, can you share the snapshot of the command prompt window showing the executed command and its output?
      Also, as mentioned earlier, please send the timestamp i.e. the time (along with the timezone) when the customer encountered the account block issue after launching Discovery/SpaceClaim.
    • Naresh Patre
      Hello rtssb9182
      Are you able to send the information requested in the previous post?
Viewing 9 reply threads
  • The topic ‘Log in new Subscription license got error appear’ is closed to new replies.
