March 7, 2023 at 3:07 am
Aliff Azrul
Subscriber​ 🛈​ This post originally contained file attachments which have been removed in compliance with the updated ​ Ansys Learning Forum Terms & Conditions​​Log in issue on name user license....although my license is emptyÂ
March 7, 2023 at 8:31 am
Devendra Badgujar
Forum ModeratorHello Aliff Azrul
I can see that Tecs for Ansys Discovery Simulation (Named User) has expired on date 2021-12-28, so you can only use Discovery versions released before this date.Â
You can download the previous versions.
Also, as you mentioned the license is not activated on any device so its empty. Once you install and launch the Ansys Discovery, you will be prompted to log in with the email and password of the user account that has the license assigned. Once that's done the software should launch successfully and will get activated on that device.
Regards.Â
March 7, 2023 at 9:07 pm
Aliff Azrul
Subscriber​ 🛈​ This post originally contained file attachments which have been removed in compliance with the updated ​ Ansys Learning Forum Terms & Conditions​​Hello Devendra Badgujar
Actually, I'm using Ansys Discovery 2020 version at first and there is no issue at all. Since old email/user not active anymore, I change to my email, assigned the subscription and suddenly, this issue appear.Â
I try uninstall and install many times with different version and still, have this issue. Furthermore, the release button did not appear when I want to release the activation for different user.
Regards.
March 8, 2023 at 12:04 am
Devendra Badgujar
Forum ModeratorAliff AzrulÂ
Please try the activating the license through Command lines and see if that helps.
Discovery Subscription license - Command line options - Knowledge Base - Ansys Discovery Forum
You will have to first release the license and then reassign; might be due to that it was not appearing. You can try activating the license on your machine and check if you can see the release button.Â
If not, we can look into it further.Â
Regards.Â
March 8, 2023 at 8:18 pm
Aliff Azrul
Subscriber​ 🛈​ This post originally contained file attachments which have been removed in compliance with the updated ​ Ansys Learning Forum Terms & Conditions​​Devendra BadgujarÂ
I have try activating through Command lines and it works! Thank you..
But, only 1 release button appear (can refer to attached picture). How to activate another release button?
Is there any steps that I missing?
Regards.
March 9, 2023 at 12:36 am
Devendra Badgujar
Subscriptions are assigned to users who have Ansys Accounts. Each subscription is assigned to a specific user but can be reassigned to a different user at any time.
If you have been assigned an Ansys Discovery subscription, you can activate it on two devices at the same time. As for your case, you can activate it on second device, and you will then see other release button.
I hope this answers your question. Thank you!
March 9, 2023 at 8:13 pm
Aliff Azrul
SubscriberDevendra BadgujarÂ
Sorry for late reply. Appreciate for your answer and advice, it works well now.
Thank you so much!
Regards.
- The topic ‘Log in license issue (Name Users)’ is closed to new replies.
- Add-in Error Excel
- Missing SubDivWrapper.dll
- Fileformats
4132
1487
1318
1158
