August 5, 2022 at 3:44 pm
k2.karimi740
SubscriberHi there,
I'm trying to couple ANSYS and MATLAB, but every once in a while ANSYS creates a lock file, stops everything. How can I deactivate this feature of ANSYS?
THANKS A LOT
Kind regards,
K
August 8, 2022 at 12:49 pm
George Karnos
Ansys EmployeeWorkbench implements a project locking mechanism in order to help prevent the project from being loaded into more than one session at a time. When the project is opened, a .lock file is created in the project files directory. The project is unlocked by deleting the .lock file.
An improperly unlocked project can occur in situations such as program crash where the .lock file is not deleted, or if the project files directory is duplicated and the .lock file is copied with it.
If you open a locked project, you are asked how to proceed:
If the file is locked because of an abnormal termination, such as a program crash, click Unlock.
If the file is locked because the project is already open in another Workbench session, click Cancel.
Opening the same project in multiple sessions can result in corrupted project files.
August 9, 2022 at 10:32 pm
k2.karimi740
SubscriberHi again,
I did so, but because I’m getting automatic runs using MATLAB, I can’t delete lock file for every ANSYS file. Is there any way to deactivate this feature of ANSYS?
Thanks a million
Kind regards,
K
- The topic ‘Lock file-ANSYS’ is closed to new replies.
- APDL, memory, solid
- Meaning of the error
3862
1414
1221
1118
1015
