March 15, 2019 at 3:05 pm
jmt714
SubscriberHi,Â
I want to apply a perpendicular and simple movement to a surface. For each time step I have the displacement. For example:
t   y
0Â Â Â 1
0.1Â 2
Therefore, I am using a transient table, a .porf file. However, unlike the udf files, the movement is applied using a reference, the global axis. Thus, the movement is not perpendicular to the surface. The only solution I've found is to align the surface perpendicular to the Y axis using spaice claim. However, this is no longer useful at the moment I want to apply a movement to more than one surface at the same simulation.Â
I would like to find a better solution than align each time my geometry.Â
Thank you in advance,Â
March 15, 2019 at 4:39 pm
Forum ModeratorHave a look at the various in-cylinder (IC) examples as that's how the valves move: check YouTube first.Â
March 18, 2019 at 10:53 am
jmt714
SubscriberHello rwoolhou,Â
thanks for the reply. The problem is with the in-cylinder method you need to define the motion in function of the crank angle. Unfortunately I don't have this information, it is a simple surface which moves perpendicular to axis where a I have for each time step, the final position of the displacement. Therefore I am not sure if the in-cylinder method is the best one.Â
Thanks in advance,
March 19, 2019 at 11:06 am
Forum ModeratorIt is, but isn't that the time of operation and not the angle?Â
March 20, 2019 at 4:48 pm
jmt714
SubscriberThe table I attached in the first post as an example, the first column is the time (in s), and the second column is the mm shifted from the origin.
Many thanks!
March 20, 2019 at 4:50 pm
jmt714
SubscriberTo clarify, I would like to impose the local movement in function on time not to the crank angle. It is just a surface that goes up and down.Â
Sorry for the inconveniences,Â
March 21, 2019 at 2:24 pm
Forum ModeratorYes, and how do they define the motion direction in the IC models?Â
March 21, 2019 at 4:06 pm
jmt714
SubscriberHello,Â
Looking in Ansys Fluent User's guide I guess using the IC output controls dialog box. However, I don't know which values I have to set in IC settings such as crank shaft speed, crank period, crank angle step size...
Many thanks,Â
- The topic ‘local movement on a surface using dynamic mesh’ is closed to new replies.
- affinity not set
3882
1414
1241
1118
1015
