September 18, 2018 at 6:13 am
Timo
SubscriberHello everybody,
I am working with Ansys Maxwell 3D and try to refine mesh in certain areas of my body. To be more specific: I have created a cylinder and now I want to refine the mesh in a thin disc inside this cylinder. I tried to split the body along the face of this disc but I dont really get the right boundary/ matching conditions on this faces.
Does anyone has an idea how to get a proper solution?
Many thanks in advance!
Timo
September 18, 2018 at 11:49 am
Mark Christini
Ansys EmployeeIn order to refine the mesh on a plane cutting thru an existing volume, first create a coordinate system at the desired cutplane. Then, use Modeler > Surface > Section to create a perfect cross-sectional sheet for the body. Select the newly created sheet (in history tree or by clicking on it) and apply a mesh operation "On Selection".
If the initial body consists of separate materials and must be split into two objects, first create a coordinate system at the desired cutplane. Then, use Modeler > Boolean > Split to divide the body in half. Use Edit > Selection Mode > Faces to choose one of the end faces at the split location and apply a mesh operation "On Selection". Adding an extra 2D sheet object between two touching objects is not recommended since it is redundant and adds unnecessary complexity to the model.
Reference Maxwell online help topics: "Creating a Relative Coordinate System", "Creating a Cross-Section" and "Splitting Objects"
- The topic ‘Local mesh refinment in Ansys Maxwell’ is closed to new replies.
- Lumped Port Deembed
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- Hfss 3D pcb via capped and filled with epoxy
- AEDT Natural Convection with default correlation is failing solver initializatio
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
- Co-simulation in Q3D, Icepak – meshing problem
4167
1487
1338
1188
