January 20, 2021 at 5:12 pm
cfd_learner
SubscriberHi,nI have done acoustics analysis in Ansys Fluent and record acoustics pressure at various receivers. I have computed acoustics signals at those receivers. Now, I want to do FFT analysis under plot-> fft and reading multiple *.ard files to get SPL at once at all receiver locations along with the Acoustics Analysis option turned ON in FFT plot options.nnHow can I perform this?.Regardsn -
January 21, 2021 at 1:47 pm
Marco Coderoni
Ansys EmployeeHello, nUsing the process receiver option you will activate the receiver list. Then you can process each signal one by one through FFT. If you want to automate the process for many receivers you would have to create a script. nFor more information you can refer to the user guide n39.10.4. Using the FFT Utility: https://ansyshelp.ansys.com/Views/Secured/corp/v211/en/flu_ug/flu_ug_sec_graphics_fft_using.htmlnRegardsn -
January 25, 2021 at 6:57 pm
cfd_learner
SubscriberWill you please explain a bit more regarding how to automate through scripting?.Regardsn
- The topic ‘Loading multiple acoustic *.ard files in FFT analysis’ is closed to new replies.
Ansys Innovation Space
1188
1076
1063
952
