Load UDF Error 126
    • rachels1001
      I have a simulation, in which the case file was created in Ansys 19.1. When I try to load it in v. 19.2 (the version I have), I get this warning when the library is loaded and auto-compiled.
      Online comments tell me that a possible reason for this is version mismatch and that I should delete the old library and compile the udf in the new version of Fluent. I have tried doing this a couple times and still receive the same error messages.
      The compiler I am using is Visual Studio 2017 with the 64-bit compiler.
      Best,
      Claire
      It looks to be compiling OK, can you retry in serial?
    • rachels1001
      I generally need to run in parallel because of the computation time of the simulation. I tried running it in serial just now and the system automatically reverted back to parallel.
      I got the same error again running with a different simulation, and so I believe it's a problem with my compiler. I have tried uninstalling and reinstalling Visual Studio 2017.
      I don't think it's the compiler as that would report an error when compiling the code. Always test on a small model, this will also help identify if it's a problem with the UDF or that particular case.
    • rachels1001
      I tried running fluent with a couple other simulations that used UDFs and I kept getting the same error. Eventually I just uninstalled and re-installed Ansys, and it is compiling properly now.
    • DrAmine
      Nice. Can you then mark this thread as "is Solved". Thanks!
Viewing 5 reply threads
  • The topic ‘Load UDF Error 126’ is closed to new replies.
