Load on element
    • TriptiPadavi
      Hi I'm trying to analyse a cylinder like structure and i want to apply pressure on the element. So how can I do that? Please help.
      Click Static Structural, click a Face, click Loads > Pressure.
      If you provide more detail in your question, you may get a more detailed answer.
    • TriptiPadavi
      Sir I want to apply pressure on mesh element. How can I select its face to apply pressure??There is no option to select face of mesh element.
      If you want to apply pressure to a small area of a large face, use SpaceClaim to draw the boundary curves on the face. This will divide the face and you can apply a Pressure load.
  • The topic ‘Load on element’ is closed to new replies.
