December 23, 2024 at 8:46 am
Raghav
SubscriberHello everyone,Â
I am doing high velocity impact analysis on ceramics where erosion card plays a significant role. I want to define Maximum principal strain at failure (MXEPS) but assigning it a particular value is showing error "load curve id 4 is undefined (Error 10141 (KEY+141) )".
This is an unexpected error as i have not defined any load curve and has to define only a particular value to it (6 in this case).
How can i solve this error? Am i defining this paramter in a wrong way?
December 27, 2024 at 9:17 pm
Reno Genest
Ansys EmployeeHello Raghav,
You are using MXEPS on *MAT_ADD_EROSION? How do you define MXEPS? If you define it as a negative number, LS-DYNA will expect a load curve number. There is more information in the LS-DYNA User Manual Vol II:
Reno.
6785
1331
1147
