December 16, 2024 at 2:30 pm
desar
SubscriberGood afternoon,
I have this problem with my license server:Â
lmgrd is not running: License server machine is down or not responding. (-96,7:11001 "WinSock: Host not found (HOST_NOT_FOUND)")
I already look in all the topics in different forums regarding this issue and try to apply the solutions proposed but none of them worked.
If somebody has some clue about a possible solution would be great.
Thanks.
December 17, 2024 at 1:23 pm
George Karnos
Ansys EmployeeÂ
Open a Dos Command prompt window.
Type in:
ping hostname
(Where hostname is the hostname of the license server)
You can try adding the hostname and ip address to the hosts file under:
c:\windows\system32\drivers\etc
###.###.###.###Â Â Â Â hostnameÂ
January 7, 2025 at 9:03 am
desar
SubscriberGood morning George,
Thanks for sharing this solution, I pinged the server and received a response.
I tried to add the IP address and hostname to the host file, but the problem was not solved.
January 10, 2025 at 4:06 pm
George Karnos
Ansys EmployeeEmail sent for diagnostics files...
February 3, 2025 at 9:04 pm
t.selover-stephan
SubscriberI've been running into this as well, and I suspect is has to do with lsb missing in my linux install
February 4, 2025 at 5:57 pm
George Karnos
Ansys Employeelsb is defintiely needed
February 7, 2025 at 6:30 pm
mwild
SubscriberMy solution was matching the server names in the license file on the client and server exactly.Â
April 29, 2025 at 3:38 pm
desar
Subscribernow it says "Error: failed to checkout feature ''lum_mode_gui"
3190
1024
962
859
798
