January 14, 2025 at 11:51 am
juhani.stenback
SubscriberHello,
When using Litz wire, does PEmag take the proximity effect into account when calculating the AC resistance for a transformer? Some documents would indicate that PEmag always takes the proximity effect into account when calculating AC resistances for a winding, but my results indicate otherwise.Â
One document I found states that Twisted wire could be used to model every strand of a Litz conductor for the actual skin and proximity effects in PEmag. My tests confirmed that there was a significant difference between the AC resistances when simulating the following cases using twisted wire: 1) where two turns were positioned directly next to each other on a toroidal core, 2) where the same two turns were positioned on opposing sides of the core. When simulating the same models with Litz wire, the resulting resistances were exactly the same.Â
Is there a possible fix for this? Or is it just so that PEmag cannot take the proximity of the turns into account, when the wire is modelled as an "equivalent Litz bundle" (as described in a document found on this page). If twisted wire could be used to model the proximity effects in transformer windings when using Litz wire, how could one do that?Â
Thank you in advance for all the help.Â
Best regards,Juhani
February 25, 2025 at 6:53 pm
MirandaH
Ansys EmployeeHi Juhani, I would suggest creating a Maxwell model from the PEmag file, Maxwell can simulate what you are looking for.
- Link the Circuit to 3D Terminals
- Magnetic Dipole moment calculation
- Integration lines or U Axis Line for circular and rectangular ports
- Core Loss in ANSYS MAXWELL Eddy Current solution
- exporting and importing my Netlist for my external circuit
- Error of Metal Fraction in Icepak Classic.
- The unit of theta in Is*sin(2*pi*fre*Time+theta-2*pi/3)
- 2D transient simulation -torque issue
- Two way coupling for Maxwell and thermal problem
4602
1510
1386
1209
