lithium battery
    • phuocdinh2622
      Hello! i have a problem in simulating lithium battery using ansys fluent. i want to check the charging capacity over time as shown below. can you help me. Thank you very much!
    • Murari Iyengar
      Hi, you can plot XY plots of Battery variables such as State of Charge (SOC) against other variables in Fluent. Please take a look at the following YouTube tutorial on post-processing in Fluent.
      For more information on plots: 37.9. Histogram and XY Plots (ansys.com)
      For more information on different variables available in Fluent: 5.5. Appendix: Supported Field Variables (ansys.com)
    • Murari Iyengar
      Here is the link for the YT tutorial.
      If you are unable to access the Ansys Online Help, please refer this discussion for a solution. How to access the ANSYS Online Help
  • The topic ‘lithium battery’ is closed to new replies.
