May 13, 2024 at 1:18 pm
mergen.eric
SubscriberHello,
I'm having trouble running Mechanical 2024 with geometry imported from Autodesk Inventor 2024. The Ansys 2024 addon/plug in is installed in Inventor. But when I try to open a Mechanical system with geometry from Inventor I get an error saying: Mechanical failed to open the database: Them Mechanical editor does not have a valid license.Â
Any idea how to fix this?
Thanks!
May 22, 2024 at 12:45 pm
George Karnos
Ansys EmployeeHi,
Under %TEMP%\.ansys directory (Your user's temp directory), you should see license debug files.
Open the one for Mechanical. What are the errors listed in that file?
- The topic ‘Lisense error importing geometry’ is closed to new replies.
