TAGGED: license, license-error, licensing, linux, redhat-license
July 19, 2021 at 5:18 pm
ihealy01
SubscriberI am trying to run an ANSYS License Server on Red Hat SUSE linux NON-GUI mode and I am getting the error below when I run Display License Status from Client ANSLIC_ADMIN Utility 2019 R2 on the client windows PC.
[Detecting lmgrd processes...]
License server status: [email protected]
  License file(s) on license-ansys: [email protected]{IP ADDRESS OF LICENSE SERVER}:
lmgrd is not running: License server machine is down or not responding. (-96,7:11001 "WinSock: Host not found (HOST_NOT_FOUND)")Â Â
Steps I used,
- Install server using ./INSTALL -LM -silent -licserverinfo 2325:1055:name
- Uploaded the license file to /ansys_inc/shared_files/licensing/license_files
- Started the license server using ./start_ansysli in /ansys_inc/shared_files/licensing
- Open ports on firewall
The ansysli_server.log file shows that the server is receiving requests but they are being denied,
2021/07/19 16:02:19Â Â INFOÂ Â Â Â Â Â Â Â Ready to accept connections.
2021/07/19 16:43:58 DENIED FLUENT_SOLVER 19.4 (2019.0402) 1/0/0/0
1/1/44/44 3016:3016:FLUENT_SOLVER:[email protected]{PC NAME}:winx64 6:{IP}
9
Capability Fluent Solver does not exist in the Ansys licensing pool.
None of the products enabling this capability are available in the specified license path:
ANSYSLI_SERVERS: [email protected]{IP ADDRESS OF LICENSE SERVER}
FLEXlm Servers: [email protected]{IP ADDRESS OF LICENSE SERVER}
The license.log file shows that LMGRD has detected the license file,
16:02:15 (lmgrd) (@[email protected]) License file(s) used: /ansys_inc/shared_files/licensing/license_files/ansyslmd.l
ic
16:02:15 (lmgrd) (@[email protected]) ===============================================
16:02:15 (lmgrd) Starting vendor daemons ...
16:02:15 (lmgrd) Started ansyslmd (internet tcp_port 47069 pid 6675)
16:02:15 (ansyslmd) FlexNet Licensing version v11.17.2.0 build 272614 x64_lsb
16:02:15 (ansyslmd) SLOG: Summary LOG statistics is enabled.
16:02:15 (ansyslmd) SLOG: FNPLS-INTERNAL-CKPT1
16:02:15 (ansyslmd) SLOG: VM Status: 4
16:02:15 (ansyslmd) SLOG: FNPLS-INTERNAL-CKPT5
16:02:15 (ansyslmd) SLOG: TPM Status: 0
16:02:15 (ansyslmd) SLOG: FNPLS-INTERNAL-CKPT6
16:02:15 (ansyslmd) Server started on license-ansys for: 1spacdes
16:02:15 (ansyslmd) a_catv6_reader a_jt_reader a_spaceclaim_dirmod
16:02:15 (ansyslmd) a_spaceclaim_faceteddata acdi_adprepost acpreppost
16:02:15 (ansyslmd) advanced_meshing agppi am_module
16:02:15 (ansyslmd) am_prep am_print ans_act
16:02:15 (ansyslmd) anshpc ansys aqwa_pre
16:02:15 (ansyslmd) aqwa_solve disco_level1 disco_level2
16:02:15 (ansyslmd) dsdxm emag ensight_enterprise
16:02:15 (ansyslmd) envision_pro explicit_advanced explicit_basic
16:02:15 (ansyslmd) granta_sim_mat_data ice_translator mat_designer
16:02:15 (ansyslmd) piautoin picatv5 piproe
16:02:15 (ansyslmd) pisoledg pisolwor piug
16:02:15 (ansyslmd) rdacis rdpara
16:02:15 (ansyslmd) EXTERNAL FILTERS are OFF
16:02:15 (lmgrd) ansyslmd using TCP-port 47069
Running netstat on the license server shows,
ansysli_s 6643 ihealy01 5u IPv4 28324 0t0 TCP *:2325 (LISTEN)
lmgrd 6673 ihealy01 0u IPv6 28697 0t0 TCP *:1055 (LISTEN)
ansyslmd 6675 ihealy01 0u IPv6 28697 0t0 TCP *:1055 (LISTEN)
ansyslmd 6675 ihealy01 7u IPv6 28701 0t0 TCP *:47069 (LISTEN)
Any idea on what the problem could be?
Thanks for your help!
July 27, 2021 at 12:01 pmANSYS_MMadore
Forum ModeratorThe message indicates "HOST_NOT_FOUND" which typically appears if the ip address and hostname do not resolve properly on the client machine. You can try adding an entry to your client machine in the C:\Windows\System32\drivers\etc\hosts file for the ip and hostname of the license server
Example:
123.45.6.78 license-ansys
Thanks
Viewing 1 reply thread- The topic ‘(linux) LMGRD Licensing Error’ is closed to new replies.
5664
1890
1419
1304
