April 11, 2024 at 7:37 pm
ydlee
Subscriberhello, i have 2 computers, one is linux and another is window,
I solved my fluent case in linux and i transferred it to window
However, i can't open the linux version case and data file in window system.
how i can open it in window system?
April 12, 2024 at 8:55 am
Forum ModeratorIt should, we routinely do that here. What error(s) are you seeing?Â
April 15, 2024 at 6:29 am
ydlee
Subscriberif i import the cass and data in workbench fluent, it showed, and automatically shut down.
Above is when i import the case and data in fluent, it showed in fluent consoleÂ
How i could opent the case and data file??
and one more thing, i imported the case and data file(window version) in workbench. and i run 5 iterations to get a green tick in solution tab
in the workbench fluent, i did it as the ansys document recommend. However it didn't change. how could i get the green tick in solution tabÂ
April 15, 2024 at 9:03 am
Forum ModeratorOK, first off, try reading the files into Fluent outside of Workbench. There are a few times when WB is useful, but troubleshooting like this isn't one of them. Now, looking at the error, have you got a UDF hooked into the solver? If so, please open Fluent, compile the UDF and then open the case.Â
April 17, 2024 at 4:51 pm
ydlee
Subscriberi just want to know how the case and data file(in linux) on window, please tell me. this is so important for me
April 18, 2024 at 8:50 am
Forum ModeratorHave you tried what I suggested on the 15th?Â
- The topic ‘Linux fluent case and data file can’t be opened in window version’ is closed to new replies.
6790
1332
1152
