3D Design
3D Design
link to download online help and release notes
    • GUICAD
      Could you please share with me a link to download the french online help and the release notes of the 2020R1 version ?
      Thanks,
    • Naresh Patre
      Hello GUICAD
      You can find the Release notes of 2020 R1 at below link
      What's New in ANSYS Discovery products 2020 R1
      The French version of Discovery SpaceClaim and Discovery Live offline help can be downloaded from below links:
      Discovery Live:
      https://drive.google.com/file/d/1tjRLw1SKIEYZnO4fE1xv9jFc6oMqHw9j/view?usp=sharing
      Discovery SpaceClaim:
      https://drive.google.com/file/d/1Xs-OXZRwO_p9TntknNnCec_9_WuKjDO_/view?usp=sharing
      After downloading the chm files, you will have to unblock them as per below mentioned instructions:
      Unblock chm file:
      After downloading a .CHM, you may need to first "unblock it" before you can use it. This is a common security measure that most computers will enforce on files that came from a different computer.
      To Unblock a .CHM:
      1. Right-click on the downloaded .CHM file and select Properties.
      2. At the bottom of the General panel, check Unblock.
      3. Click OK and reopen your .CHM.
      Rename
      After unblocking the CHM files, you also need to rename them. Rename "SpaceClaim_2019R1.chm" as "SpaceClaim.chm" and "Discovery_2019R1.chm" as "Discovery.chm"
      Copy
      After renaming the chm files, copy the files in below directory:
      C:Program FilesANSYS Incv193scdm
      Now, regardless of online or offline whenever you press F1 key the offline help document will open.
    • GUICAD
      Thanks Naresh.
      Could you please give the Italian and German version of the offline help as well ?
      Thanks,
      Guillaume
    • Naresh Patre
      Hello GUICAD
      You can get the other langauge versions from below links:
      Discovery Live:
      https://drive.google.com/drive/folders/1ARTP4jcNgHbT6pNGvwvJV23iowxetGwL?usp=sharing
      https://drive.google.com/drive/folders/19pWUxkwywm5DZ5Z_2v-e_UZdOqAkv-xC?usp=sharing
  • The topic ‘link to download online help and release notes’ is closed to new replies.
