September 17, 2024 at 8:42 am
CEROCCHI.1754896
SubscriberHi everybody, i'm struggling with the use of link 180 in ansys mapdl.
I'm trying to reproduce a sailboat rig, and i need to model some stanless cables, used to sustain the mast. I thought that link 180 only tensile would be the perfect. In some load case the cable on one side of the boat are sagging, meaning they cannot hold any compression. I'm not interest in the deformed shape of the sagging cable of course.
I triend some simply model to check the behaviour of the link 180 element used as a cable to sustain a beam, but it seems that even using seccontrol,,1 (only tensile) the result show a compression in the link elements. Why is the element not working with only tensile behaviour? any idea on how can i model the problem?
any help would be really appreciate. Thank you
Here is simpre problem whit a beam and 3 links that i used to check the behaviour:
FINISH/CLEAR/PREP7 !entra nel preprocessore!element typeET,1,BEAM188 !definisce elemento traveET,2,LINK180 !definisce elemento asta!material propertyMP, EX, 1, 69000000000 ! Modulo di elasticita MPa per il materiale 1 lega 6005aMP, PRXY, 1, 0.3 ! Coefficiente di Poisson per il materiale 1MP, DENS, 1, 2700 ! Densità lega 6005a!sectionsSECTYPE, 1, BEAM, CTUBE !definisce sezione albero circolare di provaSECOFFSET, CENTSECDATA, 0.048, 0.05SECTYPE,2,LINK,2SECDATA,0.0001,SECCONTROL,1,1!geometryK,1,0,0,0K,2,10,0,0K,3,0,3,0K,4,0,-3,0K,5,0,0,3L,1,2L,2,3L,2,4L,2,5!meshLSEL,S,LENGHT,,9.99,10.01 !SELEZIONA TUTTE LE LINEE DI LUNGHEZZA COMPRESA TRA 9.99 E 10.01LATT,1,,1,,,,1LESIZE,ALL,0.5LMESH,ALLALLSELLSEL,S,LENGHT,,10.43,10.45 !SELEZIONA TUTTE LE LINEE DI LUNGHEZZA COMPRESA TRA 9.99 E 10.01LATT,1,,2,,,,2LESIZE,ALL,,,1LMESH,ALLALLSEL!carichi!vincoli incastroDK,1,,,,0,ALLDK,3,,,,0,ALLDK,4,,,,0,ALLDK,5,,,,0,ALL!forza applicata su k2FK,2,FY,-1000000/ESHAPE,1,0 !mostra sezione elementi/REPLOT/SOL/STATUS,SOLUSOLVE/POST1/DSCALE,ALL,1 ! Use true scale (scale displacements by 1.0)SET,LAST! read the last data setPLNSOL,S,EQV,0,1.0 ! Plot equivalent (von Mises) stess/ESHAPE,1,0 !mostra sezione elementi/REPLOT -
September 17, 2024 at 8:57 am
ErKo
Ansys EmployeeHi
First use SECCONTROL,,1
ThenSee the doc./help manual on LINK180.
(Nonlinear iterative solution is needed for tension or comp. only – so use in /SOLU , NLGEOM,ON, and NSUBST etc.).
https://innovationspace.ansys.com/forum/forums/topic/problem-with-the-link180-element/All the best
Erik
5804
