Lines of temperature contours appears winding?
    • khalidb77
      Dear users,
      I tried to draw dimensionless temperature contours in an enclosure but it appeared unclear and winding like below:
      May somebody tell me the reason for that and is there a possible solution to make the contours lines uniform?
      Khalid
    • Amine Ben Hadj Ali
      Check filed under contour plots
    • khalidb77
      Hi Mr. Abenhadj
      I not willing to use filled contours I want to use lines only.
      Thank you
      The result is showing the field without filled contours: the result is that the bounds between each level are "winding". What do you expect to see?
    • khalidb77
      Hey rwoolhou,
      I expected to see the temperature lines be smooths and not overlapping into each other? similar to the mass fraction lines that appear homogeneous and clear like below:
      regards,
      Khalid
      Do not select any boundary and choose option filled. Use actual version. 15.0 is not supported.
    • khalidb77
      Excuse me Mr. Amine may you tell me what the thing that not supported in version 15?
      regards,
      Khalid
      No your software is not supported.
    • khalidb77
      But it works well with me and simulations run with it?
      Yes, that was just an info in case there is something buggy.
      Now what about the contour plot?
    • khalidb77
      Yes I do not select any boundary and again I am not hoping to use fill option
      Khalid
      Do you want to see contour? Please use filled option and post the picture.
Viewing 11 reply threads
  • The topic ‘Lines of temperature contours appears winding?’ is closed to new replies.
