July 12, 2023 at 10:04 am
Hakim Dina Anjum
SubscriberIf I pull the front of a plastic box, the sides compress. The sides can deform upto 5mm before they hit a block inside the box. I want to restrict the deformation of the side faces upto 5mm, so that I can skip modelling the block.Â
July 12, 2023 at 10:28 am
Sampat Kumar
Ansys EmployeeHi Hakim,Â
Naturally, when you pull the block face, the side face will compress, and it depends upon the material's elasticity and the amount of force applied. But if you want to restrict the deformation, then it must be anything that can provide support from the inside. You can make supports inside the box at a distance of 5 mm from the side of the box and provide contact between them so that the side of the box may not move inside more than 5 mm.
Sampat -
July 12, 2023 at 10:42 am
Hakim Dina Anjum
SubscriberThanks Sampat, just to clarify, I definitely can add supports instead of modeling the block. But is there any other way to restrict a certain DOF upto a certain value without having to add supports?Â
July 12, 2023 at 2:10 pm
peteroznewman
SubscriberHi Hakim,
Have you already pulled on the front face of the block and observed > 5 mm directional deformation of the sides of the box? If you got less than 5 mm then you can skip modeling anything inside the box!
July 13, 2023 at 3:06 am
Hakim Dina Anjum
SubscriberHi Peter, yes the sides do deform more than 5mm.
- The topic ‘Limiting deformation upto a value’ is closed to new replies.
5969
1307
