Ansys Free Student Software
Limited storage
    • Tim LS
      Hello!
      I am just wondering if it is possible to uninstall modules of Ansys that I am not using.
    • Tim LS
      Also, which workloads for visual studio 2022 is necessary to compile UDFs?
      Not with Student as far as I know. The licenced version allows some modules to be uninstalled.
      If you click "Use built in compiler" there's no need to install Visual Studio; after many years of asking for it a CLANG compiler was built into the code. I'm not sure which version we're currently supporting, but it'll be covered in some of the "Supported Platform" documents in ansys.com and then Support.
    • Tim LS
      When I try to compile the UDF with the "Use Built-In Compiler" ticked, I get the error following error message:
      Copyright 1987-2024 ANSYS, Inc. All Rights Reserved.
      Compiler and linker: Clang (builtin)
      "scons: warning: No version of Visual Studio compiler found - C/C++ compilers most likely not set correctly
      File "M:\Documents\Fluent\FlotationColumn_files\dp0\FFF\Fluent\libudf\win64\3ddp_node\SConstruct", line 20, in
      Compiler path: "C:\PROGRA~1\ANSYSI~1\v241\fluent"\ntbin\clang\bin\clang-cl
      Linker   path: "C:\PROGRA~1\ANSYSI~1\v241\fluent"\ntbin\clang\bin\lld-link
      File "M:\Documents\Fluent\FlotationColumn_files\dp0\FFF\Fluent\libudf\win64\3ddp_node\SConstruct", line 156, in
      C sources: ['FlotationKinetics.c']
      This program is blocked by group policy. For more information, contact your system administrator.
      scons: *** [FlotationKinetics] Error 1"
      Got any idea of what might be wrong?
      Try moving the work to the local machine, but also see if you can compile the UDF from Fluent standalone. There's also the last part of the error re "group policy" so please check with IT if standalone fail too.
Viewing 4 reply threads
  • The topic ‘Limited storage’ is closed to new replies.
