July 1, 2021 at 3:32 pm
KhoangKyong_NGUEN
SubscriberHello,
I am doing the chemical reaction model. I have Pre-exponential factor ( 1.36e+43 1/s ) and Activation energy (312000 J/mol) for my reaction. But when I put these values, Ansys says that the maximum Pre-exponential factor is 1e+38 only. (Pictures below)
July 21, 2021 at 3:37 pmRK
Ansys EmployeeHello This is not a limitation, this the range in which the pre-exponential parameter is defined.
July 21, 2021 at 3:44 pmKhoangKyong_NGUEN
SubscriberWonderful. Thank you very much! You just said what I already knew.
I can repeat my question if you want. My question is How to fix this problem? How I can put my value in here?
July 23, 2021 at 10:57 amRob
Forum ModeratorYou can't, it's outside the permitted range for the solver.
It may be possible with a UDF based reaction, but I'd be questioning why the factor was so high.
Viewing 3 reply threads- The topic ‘Limit range of the pre-exponential factor! [Volumetric reaction/Species transport]’ is closed to new replies.
5799
