May 21, 2023 at 8:12 pm
Sheldon Demiddeleer
SubscriberHi!
I want to analyse the flow around a simplified aircraft in 2D. I already have the geometry of the aircraft and uploaded it in ANSYS DesignModeler. Now the geometry around the aircraft and the meshing have to be done. The flow around the aircraft has to be analysed for Vertical Take Off. I was thinking of a semi-circular blockmesh with the semi-circle above. Does anyone have an idea or suggestion for a good design/meshing structure?
Thanks in advance!
May 22, 2023 at 6:28 am
Keyur Kanade
Ansys EmployeeYou will need to create geometry in DM or SpaceClaim.Â
What error you are getting.Â
Please go through basic tutorials.Â
Keyur
Fluids Engineering Courses | Ansys Innovation Courses
- The topic ‘Lilium aircraft meshing’ is closed to new replies.
3572
1188
1076
1063
952
