November 21, 2024 at 4:17 pm
Alberto
SubscriberDear all,
i'm trying to simulate the 1Degree of freedom dynamics using overset mesh method and 6dof solver with k-w SST model for the fluid.
What i'm wondering about is that for the 6dof (complete dynamics) and 2dof (i.e. allowing the object to translate and rotate along vertical z axis) i retrieve in the steady state the expected value of lift force (Fz).
Why when i'm doing the 1dof simulation (i.e. only rotation along z) where i replaced the falling vertical velocity with a ramp function up to the 2dof measured falling speed, i get a lower (15% ) value of Fz ?
This is strange cause my boundary conditions are well posed and the fluid and the solid both converges up to 10^-5 as residuals..
Can someone explain me this difference?
many thanks in advance
November 26, 2024 at 3:13 pm
Federico
Ansys EmployeeYou mention in 2DOF your object is translating in the same axis as your rotation. Is this correct?
I assume you are adding the falling velocity to the same flow you had in your 2DOF problem.
Can you show some contours of each solution?
5969
1307
