Lift and Drag Forces
    • user deleted
      Hi!
      I conduct flow simulation of the aircraft. And I try to get lift and drag forces and also aerodynamic coefficients from Ansys Fluent. But after solution I got absolutely wrong results (I compared data with experimental one). I used reference values for simulation, but it didn't help.
      What theory is used in Fluent for aerodynamic forces calculation? In theory guide I found some information only for Discrete Phases.
      Katiya
    • DrAmine
      Check chapter Computing Forces, Moments, and the Center of Pressure in the theory guide. Check this tutorial for forces
      https://youtu.be/Hq986_nn4oU
    • user deleted
      Amine, thank you! Could you please explain me how lift and drag coefficients in Fluent depend on reference values. I know it directly depends on reference area. What other reference values I should put to get correct aerodynamic coefficients?
      Best regards,
      Katya
      It's covered in DOC: click on help under reference values and look in the Field Function Variables section of the User's Guide (probably 42.2)
    • user deleted
      Thank you!
    • Seerat
      How to calculate coefficient of lift and drag from lift force and drag forcen
    • YasserSelima
      Did you read this comment?nn
Viewing 6 reply threads
  • The topic ‘Lift and Drag Forces’ is closed to new replies.
