September 17, 2020 at 9:38 pm
balensid
SubscriberI downloaded the student version of Ansys so that I can use Mechanical APDL for a class this semester. However, I get the error message, shown below, when I open launcher or APDL.
Things to note:
I downloaded and installed Ansys 2020 R2 and got this error and thought it may have been a compatibility issues. So I uninstalled 2020 R2 and installed 2020 R1. When I noticed that the error also occurred in 2020 R1, I uninstalled R1 and reinstalled R2 so that I can fix the issue on the latest version.
September 18, 2020 at 7:53 amdas.3
SubscriberAnswered here:nAnswered here:nnSeptember 18, 2020 at 1:47 pmbalensid
SubscriberHey subhamdasnI came accross this too and gave it a try, but still not working. License directories seem to be a little different between the 2019 and 2020 version. nSeptember 21, 2020 at 7:51 pmSeptember 21, 2020 at 10:17 pmtsiriaks
Ansys EmployeeHave you tried temporarily disabling security software (anti-virus, firewall, etc.) ?nAre you using VPN ?nYou can try the following command in CMD Promptnmove %appdata%\ansys %appdata%\ansys.oldnIf doesn't help, try the following commandn%awp_root202%\..\Shared Files\Licensing\winx64\ansysli_util -checkout ANS_SOLVERnwhat's the output ?nAlso, enter the following commandnsetnand show the output.nnSeptember 22, 2020 at 3:24 pmmaherpeace
SubscriberIssue is solvedThank you Tsiriaks , nSeptember 23, 2020 at 10:52 pmtsiriaks
Ansys EmployeeThat's great !nCould you elaborate so others know the specific resolution ?nViewing 6 reply threads- The topic ‘Licensing error with student version’ is closed to new replies.
4597
1500
1386
1209
