February 23, 2024 at 4:12 pm
egge5901
SubscriberHello, I am having difficulty getting licensing to work on my machine.Â
I am hosting the license locally on my machine with hostname and disc serial number.Â
When I try to start the Flexnet server, I get the following error.Â
Additionally, I get a blank popup window here when I try to run the licensing interconnect.Â
February 26, 2024 at 10:02 am
Rajeshwari Jadhav
Forum ModeratorHi Bjorn,
Please share the screenshot of your license file, first 5-6 lines and on Ansys License Manager did you upload your license file through "Add a license file" option and then click on View status/start/stop license maanger -->start Send screenshot of "Get system Hostid Information" too.
February 26, 2024 at 3:10 pm
February 26, 2024 at 3:25 pm
Rajeshwari Jadhav
Please confirm if License Manager is up and running I don't see any green check mark on your LM.
Also, can you please escalate this case through your Ansys Account Manager, just mention my name Rajeshwari Jadhav, it will also us to view your logs via mail.
March 10, 2024 at 5:08 am
March 11, 2024 at 7:16 am
Rajeshwari Jadhav
May I know who is your account Manager?
March 11, 2024 at 12:06 pm
egge5901
SubscriberMy account manager is Santiago Ibarra.
March 11, 2024 at 12:08 pm
Rajeshwari Jadhav
Do you get any errors while launching the workbench?
March 11, 2024 at 1:31 pm
March 11, 2024 at 1:38 pm
March 11, 2024 at 1:40 pm
March 11, 2024 at 1:46 pm
Rajeshwari Jadhav
Forum ModeratorUnder web licensing Shared is off right?
Also set the following Environment Variable –
Go to START > ‘Edit the System Environment Variables’ > click Environment Variables.
Under the System Variables, please click NEW and create a new variable.
Variable Name – ANSYSLMD_LICENSE_FILE
Variable Value – 1055@BEP15
March 11, 2024 at 1:58 pm
egge5901
SubscriberWeb licensing Shared was on, but I turned it off. I also made a new system environment variable that you said and nothing changed.
March 11, 2024 at 2:16 pm
Rajeshwari Jadhav
Forum ModeratorGo to C:\Program Files\ANSYS Inc\Shared Files\Licensing open ansyslmd.ini file remove shared web licenisng line and save it, you can share screenshot to be sure.
In start menu type %appdata% and delete Ansys folder, same way delete .ansys folder type %temp%.Â
March 11, 2024 at 3:00 pm
March 15, 2024 at 9:41 am
Rajeshwari Jadhav
Forum ModeratorSave it to the document first then you can move it to  C:\Program Files\ANSYS Inc\Shared Files\Licensing folder, it will be replaced.
April 8, 2024 at 6:01 pm
egge5901
SubscriberSorry for the delayed response! School for busy for a little bit. I was able to complete those steps successfully, what should I do next?
April 23, 2024 at 12:45 pm
- The topic ‘Licensing Difficulty’ is closed to new replies.
5674
1890
1419
1304
